LSD
Originally Posted by Elistan,Dec 17 2007, 12:21 PM
No, he's right. Torsen type LSDs act like open diffs when one wheel is off the ground.
The T-2 has the plate to compensate, ours does not. Even both on the ground, the Torsen doesn't fully lock, but that is why is is so streetable.
The OP wants to know if the car will drive "faster" with a 1.5, sure, but it will change the driving dynamics considerably. It will not stop oversteer. IMHO it will not make the act less prone to oversteer in the wet. It is a fair bit of money and only appropriate for someone with a lot of experience. AFAIK Get a bunch of track drivers classes and then make that decision.
In my personal experience with my Kaaz 1.5 LSD I have had no ill experience driving the car. The car will push a little through a turn but, it is controllable. In wet weather I am mindful of the rear push and drive with more care and caution. So far it has been a pleasurable experience and has raised the fun factor of the car quite a bit. I also have 4.56 gears and a AP2 transmission.
I am no great driver by any stretch, I am going to an instructional driving course on January 12th. I will find out then how much of a change it is over the stock LSD. I have done a little auto x before with the stock LSD, so I have something to compare to
Note that a plate type diff will lock when the wheels are turning at different rates (i.e. through any turn), while a gear type LSD (like the S2000 has) will lock only when torque is applied.
So for example in slippery conditions, if you coast through a turn the gear type diff will stay open while the plate diff will lock.
That's the theory though, my 928 had a plate diff and still was much easier to drive in the wet than the S2000 with a gear type LSD.
Regarding lifting a rear wheel, you'll only be able to do that on track and with a non-standard suspension setup. If you do lift a wheel, the OEM gear type LSD will indeed spin away power.
Originally Posted by afwfjustin,Dec 17 2007, 07:00 PM
To the OP, did you notice my previous post? A larger front anti sway bar is what you need. You can get one for around 150 bucks and takes 2 hours to install if you're lazy and drunk.
I'm no Raider's fan - in fact I couldn't tell you 3 football players if you offered me 1 million dollars
Go to youtube and do a search for "whistle tip"
Aww hell, here you go: http://youtube.com/watch?v=eSOSJ68xOBA
