Modifry redline shift beeper
Anyone put one in an AP2? The pics in the instructions look different from my 07(I am guessing the pics are from an AP1). I can't seem to get to the tach wire. Any suggestions?
Heres the instructions for MY06/07 install:
"So far, I only did the first part of the install (the non-optional part). There are some minor differences from the pictures given in the online instructions.
The panel on the passenger's side uses two push-to-release pins and one phillips screw in addition to the other pry/pop off fasteners. I used the official honda-specified tools but they weren't needed for this simple task, almost any prying tool would probably work (pref. something wider than a screwdriver).
On the 2006, the convertible top connector/module appears the same as in the installation pictures.
However, on the 2006, the connector (C204) with the tach wire appears a bit different. It is turned 90 degrees, appears to be mounted a bit further inside and more to the right (as compared to the picture in the installation document), and also now has a small yellow box attached to its side. (This little yellow box is about 1 inch by 1/2 inch by 1/8 inch, and has a wire coming out of each end.) I had difficulty getting to the connector itself, so instead I just took off some of the electrical tape from the wire bundle that is going into the upper end, and located the tach wire as described in the instructions (the only medium blue with no lengthwise stripes - it does have some silver bands though.)"
I just installed mine last week. Also, if you email modifry he'll send you a picture to get you a better idea.
S2000_Europe
Mar 1, 2008 09:14 AM
