more hp
Old May 21, 2007 | 05:35 PM
dimonda422341's Avatar
Default more hp
hey sorry i am new to the f20c engine but i just have a quick question, is there any way to extract 50-60 more horsepower out of the engine with out going to turbo, superchargers or nitrous, responses are appriciated thanks
Old May 21, 2007 | 05:58 PM
R3DS2K's Avatar
n/a would be changing the internals, going higher compression, and running higher octane rating..
Old May 21, 2007 | 06:08 PM
gomarlins3's Avatar
Yes, but it would cost less to go with boost.
Old May 21, 2007 | 06:24 PM
s2kforlife's Avatar
stroker kit with some other things and you'd be close to your goal i believe. But that's gonna take some BANK
Old May 21, 2007 | 07:37 PM
afwfjustin's Avatar
Nitrous will do that for around 1K.
Anything else and you're looking at 5K +
Old May 21, 2007 | 08:10 PM
SimpleMan's Avatar
Just add another VTEC.
Old May 31, 2007 | 05:33 PM
SilvCF2k's Avatar
Heres some forums that you should look at.
https://www.s2ki.com/forums/index.php?showtopic=472353
https://www.s2ki.com/forums/index.php?showtopic=432384
https://www.s2ki.com/forums/index.php?showtopic=459768
Those threads are on NA builds. The last one has A LOT of info on it.
Old May 31, 2007 | 05:36 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Yes.!!! very possible.
How much money,do you want to invest.???
Old Jun 1, 2007 | 09:32 AM
__redruM's Avatar
What about a "Type-R" Sticker. They add about 25hp each, so put one on each bumper.
Old Jun 1, 2007 | 02:38 PM
toofast4yalll's Avatar
The first thing new buyers should learn about this car, as I have said in countless other n00b posts, is: IF YOU WANT CHEAP POWER DONT BUY AN S2000! This is the last sports car on earth that will make that kind of power without forced induction. In your case, it would be cheaper to go FI. 50hp NA requires stroker kit, higher compression pistons, ITBs, AEM standalone with a GREAT tune, Hytech header, 3" header-back exhaust, serious head work, most likely bigger fuel injectors, etc. You will then have 240-260whp. For half the money of all that, you could have a supercharger or Greddy turbo kit and on stock internals have a little over 300whp. If you want to be able to cheaply and easily make NA power, you need a high-displacement engine. Anything with an LS1 in it should suit your tastes. It will be cheaper to buy and cheaper to make power with. However, good luck making it handle or brake better than your average Honda Odyssey.
