Muz 1 piece floor mat mod
I bought the Muz floor mats, but had trouble with the driver's side moving around on me. I think most of it was caused by the friction of the heel pad against the bottom of my shoes. I bought some 3/8" grommets from Home Depot, and installed one in in the same location as the grommet in the factory mat. It works really well - no more sliding around! The only thing is that I was unable to find black grommets - these were gold. But, a little black model paint and they will look great. I reccomend this to anyone having trouble with their Muz floor mats moving around on them.
Sticky velcro attached to the top of the cross-bar and the bottom of the ridge on the mat, just in front of the logo, works great, too. I had both sides sliding around a lot, and this fixed it right up.
Originally posted by slaughterj
Hey, maybe Muz could work a new version with a grommet built in?
Originally posted by SilverFog
Would you consider making it an option on your mats, Muz? That is, with or without the OEM mat-post grommet?
Yep.. if you want it.
I can't remember the manufacturer of the grommets, but it comes as a kit - I got it at Home Depot. I bought the 3/8" grommet kit, and it comes with several metal grommets, a punch (to cut the hole), a lower "die" and a drive pin that actually attaches the 2-piece grommets together. The directions are on the package. The hardest part was that the grommets are not meant for something as thick as the floor mats, but you can make it work. When complete, it gives a really clean look, and is much stronger than any rubber grommet. I have bought grommets before at boat supply places (people use them to attach boat covers and tarps). If anyone needs more help, let me know.
This is due to the mats being rolled during shipping and the edges curving upward a bit. They will take a few weeks to settle properly. Removing and re-installing them once flat should alleviate this.
Regardless, I have made the driver's side grommet an option (in black) as requested. I was considering a less grippy heel pad but it would mean using cheaper materials which I don't want to do.(I kinda like the decent quality rubber)
[Edited by Muz on 04-16-2001 at 02:14 PM]
