My 18" Volks are coming next week...any advice for the install?
Ok guys - my 18" Volks will be here next week, so I am doing a final check on anything I may have forgotten. Some questions I have:
Should I get an alignment done as well as the obvious mount and balance?
Do I need to buy a yellow box to correct the speedo/odo or is there an alternative method to doing this (say a visit to the dealer for ECU programming or something)?
I can't really think of much else - the tires are in the garage just waiting to be put on but since this is the first time I've bought aftermarket rims I thought there might be some lessons learned
As long as the overall diameter remains the same a speedo correction device (yellow box) isn't needed. As for the alignment, if you currently don't have a problem you are fine. Unless you are lowering the car at the same time.
Fronts:
Old: 24.9
New: 25.1
Rears:
Old: 24.9
New: 25.0
Is that close enough or a problem?
Terd: The rims are brand spankin new so they've never had tires mounted on them!!
Any recommendations on where to get them mounted/balanced?
Old: 24.9
New: 25.1
Rears:
Old: 24.9
New: 25.0
