MY 2004 17" Wheels
Old Dec 14, 2003 | 07:17 PM
S2KPHX's Avatar
Does anyone know if the MY 2004 17" factory wheels will fit on MY '00 - '03?
Old Dec 14, 2003 | 07:39 PM
4IGS2000's Avatar
Spammer
yes they are fine
Old Dec 14, 2003 | 09:56 PM
mike2k's Avatar
OK, I assume they have similar offsets, but then keeping the performance in mind:
what tires and sizes would you use, lower pofile to keep the same outside diameter ? and would you need to lower the car ? also possibly different wheel alignment ?
Old Dec 15, 2003 | 04:25 AM
HI SPEEDR's Avatar
When Honda changed over to 17" wheels of MY04, they also modifed other parts of the suspension as well. Check this out before doing this mod.
Old Dec 15, 2003 | 04:39 AM
SkipX's Avatar
Anyone know the REV's per mile on the 2004 245/40 17" Bridgestone Potenza RE050?
The 00-03 REV's per mile on the 225/50 16" Bridgestone Potenza S-02 is 840. As per TireRack.com
140AA 1389lbs. 44psi 10/32nds 6-8" 7" 9.2" 8.5" 24.8" 840
-Skip
Old Dec 16, 2003 | 03:51 AM
SkipX's Avatar
Bump, or can this thread get moved to the TireRack Forum.........
Old Dec 16, 2003 | 07:53 AM
Palmateer's Avatar
The stock 00-03 wheels would be MUCH easier to keep clean
Old Dec 16, 2003 | 11:27 AM
Zach H's Avatar
Some of you guys are way too anal about wheels and tires for the S2000. It's pretty bad when you question Honda's wheel fitment on their own car. Why wouldn't 04 wheels fit on an 00-03? They are the same car.
Old Dec 16, 2003 | 11:45 AM
3ngin33r1's Avatar
Because they aren't the same car. You may want to look into everything that was changed with the suspension before saying something like that.
Old Dec 16, 2003 | 11:48 AM
stockae92's Avatar
[QUOTE]Originally posted by HI SPEEDR
