my S stalled..
Just wondering if anyone has had this experience.
For a week my S had a dead battery and I just put it in a few days ago. It continued to rain here in Nor Cali, so I just put in the new battery and let it sit.
Today the weather outside was too nice to resist, so took out my S.
It fired up all fine and all, but a block down at the stop sign, I made a full stop and the RPM had 2 bars and it was choking and it stalled! I was in nuetral.
I started the car again and again it was shaking and RPM had 2 bars, I gave it gas and drove.. It continued to shake every time I stopped. so I kept on giving gas at traffic lights. Maybe after 5 more full stops, it seems to be fine, but
This has never happened before and the only thing is the dead battery.
I know the dead battery reset the ECU, but will that cause it to stall and choke?
FYI, it's a 03 with 37k healthy miles...
Thanks a lot for ANY information in advance..
But would it stall tho? I've had batteries go dead on previous cars but none stalled..
I really hope everything will be alrite especially now that it doesn't have warranty anymore..
ps. Why are you in neutral at a stop sign? If you are coasting to the stop sign in neutral, this will also contribute to the problem not to mention that it's not safe driving technique.
Originally Posted by Nicky o3,Dec 24 2005, 06:43 PM
Why is this an unsafe driving technique? What should we rather do?
The only time you would be in neutral is when you need to have the clutch up and you are not moving, like when you are warming up the car or sitting for a long period of time at a stop light. As long as the car is moving, it should be in the correct, corresponding gear for the road speed. If you are stopped for a very short time, you should be in 1st, clutch in, so that you are ready to move off. You should have learned this when you learned how to drive "stick". If you were not taught, then whoever taught you, was remiss. As you get into driving "stick", you should also be learning things like "rev-matching", but this is a topic of a whole other thread and has been posted numerous times here.
The above is a matter of proper driving technique. Now, for a mechanical explanation .................................
There are example of cars where the speed signal is interpretted along with all the other sensors that provide information to the ECU. In some cases, when the ECU sees road speed and "neutral" and ZERO throttle position, this can confused the ECU into doing odd things. These things can include a "hanging" rpm or extremely low idle speed leading to a stall.
Originally Posted by my_s2k,Dec 24 2005, 08:25 PM
hmmmm....
then should i just reset the ECU again? and let it idle low and die?
Originally Posted by xviper,Dec 24 2005, 06:44 PM
NO! Don't use the ECU reset thing too freely. It has to be given the opportunity to learn. Every time you reset it, it has to learn all over again. After a few episodes, it should stabilize if you're not messing with it by "helping" it. If it doesn't resolve itself after a few days, you may need to look into doing other things. Post back here then if it continues into middle of next week.
Thanks A LOT for your help!!
