NA AP2 Dyno Sheets
Old Dec 5, 2006 | 11:48 PM
tcjensen's Avatar
Default NA AP2 Dyno Sheets
AP2 Owners,
To help myself and others decide on AP2 NA power mods, I think it would be awesome if all those with real dyno sheets could scan them and post them here for reference.
I may get little to no responses here, but I would like to attempt to start a sort of reference thread of ONLY dyno sheets with mod lists for ONLY AP2's.
With the dyno sheets, please list TYPE of dyno (i.e. dynojet, mustang, dynapack, etc) and mods-including lightweight rims and flywheels.
Don't know if I can make this request, but . . . please do not post what you got by just typing it here. (There is way too much typing and talking in other NA tuning threads) I would love for this thread to become a reference of REAL dyno numbers on AP2's with REAL dyno sheets: both stock baselines and modded.
Thank you very much should you decide to post your ACTUAL dyno sheets with your applicable modifications. It would be a tremendous help to other AP2 owners.
Old Dec 6, 2006 | 07:38 AM
Johnny Sack's Avatar
check page one of the "offical NA tuning thread" in the JDM section. you'll see dyno plots and a comparo there.
Old Dec 6, 2006 | 07:40 AM
mugenrsx's Avatar
AP2 top
AP1 bottom
AP2 = gutted airbox, resonatorectomy, krank vents
AP1 = stock
Dynojet
Old Dec 6, 2006 | 09:42 AM
tcjensen's Avatar
mugenrsx,
perfect. Thank you. Anyone else?
Old Dec 6, 2006 | 10:24 AM
Elistan's Avatar
Here's a couple stock MY04 cars on the same day. This was in Nov '03, so they each had less than 1000 miles.
Old Dec 6, 2006 | 12:53 PM
tcjensen's Avatar
Elistan,
Great information. Thank you. Keep them coming, stock and modded!
Old Dec 6, 2006 | 03:14 PM
INDYMAC's Avatar
2004 S2000 completely stock with 3000 miles
Dynapack:
1st run
141.0 ft/lb
209.6 Hp SAE
2nd run
146.9 ft/lb
206.9 Hp SAE
Only 2 runs made
Old Dec 6, 2006 | 03:24 PM
minboost2's Avatar
In the top right corner of the DynoJey dyno sheets, you'll see the "CF:" value, which is the correction factor.
CF: Std reads higher than CF: SAE.
For example, in the first dyno sheet in this thread, it looks like the AP2 had around 203-205 whp. SAE would put this around 198 whp (and would lower the AP1 on the same dyno as well).
I believe SAE is the standard correction most people use. Be careful when comparing dyno sheets! Correction can make a big difference.
This is a DynoJet 248c of my stock AP2 with CF: STD.
Old Dec 6, 2006 | 03:27 PM
wildcardtrd's Avatar
^^^very true
Old Dec 6, 2006 | 03:56 PM
tcjensen's Avatar
INDYMAC and minboost2,
Thanks for your contributions!
(wildcardtrd, love your setup
