NA guys with comptech flywheel...
well not really slow you down. theoretically you'd accelerate quicker, you just need to make sure your actual speed is up to par. because you may be revving quicker, but not reaching set speed any quicker.
i havent done the mod yet, but what i mean is just normal driving under 3000 rpm shifting, the gears are already so short that before you know it you're in 4th gear doing 40.
Originally Posted by thetz99,Feb 23 2006, 01:04 AM
Have you done the AP2 clutch delay mod? Might be your issue if you're experiencing clutch slipping.
I have the Comptech flywheel and I really like how it makes the engine respond when shifting and heal-toe'ing. It makes driving more enjoyable. I haven't noticed any acceleration increase however.
well for what it's worth, i've raced my buddies 3.2Cl-S 6mt a couple times before i put in the flywheel, and a couple times after. I pull a bit harder on him now since the flywheel. I figure since there is less rotational mass in the drivetrain when you install a light weight flywheel, you get less parasitic loss. I'd assume this means more power to the ground. Exactly how much? I have no idea.
For you guys that are saying that the gears won't get you to the same speed as fast : Have you seen the video that's around with the two S's racing? One has gears and one dosen't. It's obvious that the one with gears was much faster or at least accelerated much faster.
