need help with clutch fluid
Old May 28, 2008 | 03:03 PM
icecreamballer's Avatar
Default need help with clutch fluid
my clutch is starting to lose lots of pressure. so i checked and my clutch fluid level is way to low and it turned black. i should have taken care of my car better but anyway. dealer is telling me about 100bux to get it flushed
what do you guys think?
Old May 28, 2008 | 06:05 PM
BEASTMODE's Avatar
That sounds a little high, but Ive never had it done.
gomarlins3's Avatar
You can find it cheaper.
Old May 28, 2008 | 06:10 PM
finalkillss's Avatar
if you have the means try doing it yourself.... i dont think it would be too hard to do. But it sounds about right 100 dollars, dealerships charge alot per hour, the acura dealer down here charges 100 an hour just for labor. If you can find a regular garage they might do it for around 45 50 maybe.
Old May 28, 2008 | 06:37 PM
Sabre's Avatar
I just did it myself tonight for the first time.
Took me all of about 20 minutes. It's REALLY easy.
$5 for a bottle of DOT3 and a friend to help work the clutch, done deal.
Old May 28, 2008 | 11:11 PM
hey, really? the dealer guy said there's no drain out for it so they have to flush it out. otherwise i would do it myself.. so i guess it is doable to on your own..
Old May 29, 2008 | 01:16 AM
terahertz's Avatar
well it depends what you mean by drain and flush. first you should use a turkey baster or something to change the fluid in the reservoir then proceed to use the bleed valve on the slave cylinder to bleed the rest of the system. there are a couple do it yourself threads on this forum.
Old May 29, 2008 | 03:42 AM
mlc's Avatar
mlc
You can definately do it yourself. Here is a good write up. I did it with my wife in about 30 minutes(whole job).
http://forums.s2kca.com/showthread.php?t=12154
I would never pay $100 for the stealership to mess up my car. But that is just me.
mlc
Old May 29, 2008 | 06:27 AM
Sabre's Avatar
mlc
that's the writeup I followed.
Old May 29, 2008 | 08:38 AM
thank you thank you
