Need help to do it right/safely....
Old May 3, 2001 | 12:32 PM
Mark_12345's Avatar
I'm raising my seat about .75 - .50 inches so my amp will fit.
I was able to find the proper bolts for both the rear (10mm) and front(8mm) with a thread pitch of .1mm.
However I'm not sure what to do about the washer...should I buy a bunch of washers to raise it or someone told me to use a large bolt (which may require 2 bolts to get it the length that I want).
ANY help with this I would greatly appreciate.
I need to do it right and safe.
Don't want the seats to come off when I'm doing 1.0G's ;-)
Old May 3, 2001 | 12:35 PM
Phantom's Avatar
Mark_12345,
Ahhman...I don't know about that one.
Why don't you put the amp where the spare tire is?
Old May 3, 2001 | 12:39 PM
justification's Avatar
Have you considered the consequences of air bag deployment and the roll bars?
Not that I have. Just a thought...
Old May 3, 2001 | 12:40 PM
Mark_12345's Avatar
aka Unicron,
I prefer under the seat. What could possibly go wrong? ;-)
I think putting the amp in the spare might be more work...correct me if I'm wrong.
How do you keep the amp from moving in the spare?
Old May 3, 2001 | 12:46 PM
yogi's Avatar
you might want to think about heat buildup too. you don't want to make the fit too tight.
Mark_12345's Avatar
justification,
What does the airbag and rollbar have to do with raising the seat .5 - .75 inches?
Please explain.
shingles's Avatar
Originally posted by Mark_12345
aka Unicron,
I think if you REALLY want to do this, you should go get a piece of metal plate of the right thickness cut and drill a hole. I wouldn't do this stacking washer business... just sounds rather scary to me...
-Shing
Old May 3, 2001 | 12:48 PM
1Y2KS2K's Avatar
I wouldn't recommend using a bunch of washers (which can sheer or distort). You should try to find the right size spacers and larger/longer bolts - preferably made of hardened steel. Try one of the bigger Pep Boys stores; they seem to stock a good selection of assorted bolts. If you have any problems finding what you need, try an online search in Yahoo for nuts & bolts.
Old May 3, 2001 | 01:11 PM
Penforhire's Avatar
Mark, please post your results after you're done. There's lots of things that would fit under the seats if we only had a bit more space.
Old May 3, 2001 | 05:42 PM
Muz's Avatar
Muz
Former Sponsor
aka Unicron,
I think the poster is suggesting you do away with the spare like some other owners have.
See this thread for pics...
http://www.s2000online.com/forums/showthre...p?threadid=1995
