Need Help Installing Xbrace Asap!!!
Old Sep 12, 2002 | 11:57 AM
mwy23's Avatar
hello guys,
well, i'm installing my xbrace now and i'm running into a problem. all the bolts went in fine, except for the front left. it goes in about 2 turns and then backs out to the beginning again. the bolt is fine, and i hope i didn't strip the threads on the car itself...i have no idea what to do. any and all help would be greatly appreciated!!!
oh, by the way, the front stock bolt gave more resistance than any of the other bolts when taking them out. do you guys think this might have anything to do with the problem i'm facing?
thanks.
mike
Old Sep 12, 2002 | 11:59 AM
Aaric's Avatar
make sure not to tighten any of the bolts before you get them all started.
If you screw them in more than just starting them at first, you can run into problems.
Old Sep 12, 2002 | 12:00 PM
turbo_pwr's Avatar
Did you try taking the other bolts out and tighten the front left one first?
Old Sep 12, 2002 | 12:02 PM
mwy23's Avatar
aaric...i did that first, and then tightened...did the front left one last...and ran into that problem...
turbo...i took off the xbrace and tried reinstalling the stock nut back in that front left hole and run into the same problem again...with the stock nut!!! what's going on!!!
thanks for the super fast responses tho!!!
Old Sep 12, 2002 | 12:09 PM
mwy23's Avatar
thanks again for the super fast responses...
well, got the bolt in...apparently it just needed some force under the bolt pushing it in with some turning...got it in and torqued down and installed!!! thanks again guys!!!
mike
Old Sep 12, 2002 | 12:19 PM
turbo_pwr's Avatar
Good to hear. Now go out find some twisty roads and break the sucker in.
Old Sep 12, 2002 | 01:41 PM
mwy23's Avatar
break in??? i have to go through a break in process with this brace??? aww man!!! another break in process!!!!!!!!!!!!! the first 600 miles were hell!!!
Old Sep 12, 2002 | 02:35 PM
turbo_pwr's Avatar
break in, referring to use the damn, put it through it's paces
Old Sep 12, 2002 | 09:25 PM
rossmon1's Avatar
glad to hear u got it in ok, that is a damm touchy install if u have little experience or zero patience! i had to fiddle with things for quite a while but finally figured where to carefully finesse alittle with the mondo screwdrivers on the sub frame to get things lined up for the easy penetration
nice_tan
Mar 13, 2017 02:51 AM
manolo.cabasal
Dec 10, 2009 01:50 PM
1QUICK1
Sep 15, 2004 08:07 AM
Incubus
Nov 11, 2002 11:25 AM
Hootsama
Mar 1, 2001 06:41 PM
