Need help....specially from nitrous people....
Old Mar 10, 2006 | 05:06 AM
CIVICTOS2000's Avatar
Default Need help....specially from nitrous people....
I was wondering what was the better way to run my nitrous line from the trunk to the engine? also its there a plug in the trunk or if I decided to go from the bottom of the car will I have to drill a hole ? Thanks a lot
D.
Old Mar 10, 2006 | 09:05 AM
I know there is some people out there running nitrous kits.....
Old Mar 10, 2006 | 02:46 PM
FF2Skip's Avatar
It all depends on where you plan on mounting your tank.
Old Mar 10, 2006 | 09:53 PM
I'm planing on mounting it in the trunk...thats why I was asking about the drain plug in the trunk, if there was one I could run it through there....I'll check sometime under the car to see If I see any.....but I still take some options and opinions from people that have done it before....
D.
Old Mar 11, 2006 | 04:42 AM
FF2Skip's Avatar
Yes, I figured out you were putting it in the trunk, but the trunk has many different areas. I am now guessing that you want to put it in the tool well. If you choose that route, be sure to caulk the hole after running the line so as not to let road spray(both wet and dry) enter the vehicle.
I have spent much time in the trunk of my car(fiberglassed the tool well ) and am currently in the process of gathering my nitrous items.
sam i am
Aug 29, 2013 07:54 AM
Aren
Jun 14, 2007 03:43 PM
