Need help trying to install an extra hid system!
Maybe i am crazy but i am going to install another hid system for the high beams, just wondering what i should be worried about, if anything?
You will have some issues with replacing the globe as I haven't seen any where that prduces a HID globe with a compatible base to replace the standard halogen 55W globe because the standard globe is much shorter in the body then a HID globe and you have to retain the focal point. I have also read about very bad results from these globe swaps because of the different size of the light source compared t a halogen globe.
More importantly firstly you will loose your "flash" capability as the HID won't ignite in time to give a significant flash, secondly I think if you check you will find most US States don't allow the modification of the standard lights. Of course with the second point it would have to be a picky officer to get upset and we know there aren't any of those out there...
A better proposition would be to fit a set of auxillary HID driving lights, there are plenty in the US not like Oz where there are a grand total of "none", just use HID in your favouritr search engine.
LOL.
LOL.
Fitment is no problem, but would it burn the stock casing , i can make it fit by doing some custom resizing, like i did for my strobe lights ( sho me) but will it burn or will anything bad happen...
As you seem reticent to look yourself I've done it for you.
mdigrappa (of billet X brace fame) is the gent with the H1 HID's.
Here's the thread:
https://www.s2ki.com/forums/showthread.php?...ht=HID+Phillips
Here's the thread:
