need opinion from u guys about my s2k~
i got a 04 s2k. . but now encountering a problem..i hope u guys can hlep me to give some opinion to let me handle with that... i live in st louis MO..during the past week...High: 21 almost.. so when i wanna start my s2k every moring in the garage which is not easy, do u guys know what i mean? i mean the car takes long time to start it than a month ago.... and some times i got try the second time...
do u guys have the same problem in the north? please let me know what do u think...thanks...
by the way .... what kind of oil do u guys chose? dose the problem cuase by the oil? i think i m using the honda's genuine oil, is it good? i dong't thingk so
I live in Southern New Jersey and the mornings here have been below freezing when I have to go to work, 6AM. My garage isn't heated but the car starts first time, everytime. I let the car warm up a little before I drive if it is cold out. I use Mobil 1 10w-30, this may have something to do with your problem. Too thick an oil may hinder the cold morning start up. Not sure though.
First thing I'd look at is battery. Second would be fuel pressure. If the fuel pressure bleeds down then they're hard to start first thing on the morning.
Fuel pressure leaks down from leaky injectors, leaky tank check valve or leaky fuel pressure regulator.
Do this, turn on the key, wait 2 seconds, turn it off, then turn it on again and try to crank. If that makes it fire right up. It normally means your fuel pressure is bleeding off during the night.
If it cranks slow in the cold mornings, you need a battery.
I just got my battery replaced about 4 months ago, recently about the last month or so....since it has been getting cold, my car takes a little longer to start too. However, I park outside. It has been about 55-60 degrees out you guys think it is normal?
Thread Jacker
i m using the honda's geniue oil that comes from the dealer... i awalys changing oil in the dealer.... i think is 10W-30... i did check my battery, shows me ok ...and my car just 15k miles, so will not be changing right?
en ...actually..it is cranking slow to start up.... so ..
what u guys think agian? do i need to change oil?
