need some major help
Old Dec 28, 2006 | 03:43 PM
krazyguy316's Avatar
Default need some major help
ok just recently i started to notice the car acting funny. Everytime i accelerate the car wiould want to go to the right, but when i let off it goes left. And when i drive normally its ok. Its just that when i start getting on it it wants to turn right and if i let off i would have to correct my steering so it wouldnt go left. Anyone know whats wrong?
Old Dec 28, 2006 | 03:47 PM
hpark's Avatar
don't panic, check the minor things first like tire pressure.
Old Dec 28, 2006 | 03:52 PM
S2kracka's Avatar
Make sure your tire pressure is even (both fronts same, both rears same), if that doesn't work get your car aligned.
Old Dec 28, 2006 | 05:24 PM
yea ill have to check the tire pressure tomorow morning. I dont knwo if its the springs i installed awhile back. I never got to get the alignment done. Another thing i think might have added to the problem is the rear sway bar i believe. Ever since i put the exhaus system in i couldnt get the bar back in because the piping is so big. I will chek the tire pressure tomorrow and see hwat happens. Does anyone know what the tire pressure should be at?
Old Dec 28, 2006 | 05:41 PM
FearlessFife's Avatar
And get it alinged QUICKLY if needed. It only took 1K miles to go through rear tires that had half tread to begin with when I was out of alignment...granted it was way out of alignment, but it is not something to wait to take care of.
Old Dec 28, 2006 | 05:45 PM
FISH22's Avatar
when i first had my 03, i freaked out, cause my car would pull to the right, sure enough, one of the rear tires were 10 psi low
Old Dec 28, 2006 | 11:56 PM
yep you guys are right. Its dark but i started to get really irritated with this situation because i cant drive the car the way i usually do beacuse of this problem. So i jut got home its dark and i got a flash light out. Walk around the car and notice the rear right tire to be a lil flat. And i just sat there wondering why the hell did it get so flat. Inspected the tire and what do you know.... a freakn nail is dead center in the tire. Now i gota find some new tires errrr thanks guy's
jondele
Feb 8, 2007 12:02 PM
bulldogs2k
Jul 7, 2006 10:30 AM
Jaydem
Feb 14, 2006 08:57 AM
Icemn2003
Nov 3, 2003 11:28 AM
Mclaren
Apr 1, 2002 12:14 PM
