Negative Camber.
Old Mar 17, 2008 | 08:26 AM
tbonesteak's Avatar
Default Negative Camber.
Hey Guys, here is my current setup.
18" LE37
7.5f/8.5r
+48f/+50r
225/40r , 255/35r
Alignment settings:
-.9 front
-2.3 rear
6.5 caster front
1/32 toe in front
1/4 toe in rear.
The problem is......i RUB!!!! hahah. SO what's the maximum negative camber allowed in our cars so that i can stop rubbing??? yes yes, i know it'll cause bad camber wear on my tires but at the moment, i drive 2 miles a day to work and back and i dont have the time and the money to shell out 215/245 tires. Thanks in advance.
Tim
Old Mar 17, 2008 | 08:56 AM
sirbunz's Avatar
Driver side front usually has limited camber. My '05 was only able to get about -1.5 and -1.3 with me in it. Passenger side front can usually go over -2 and the rears close to -3 on AP2s in my experience. My CR was the same except that the drivers front was able to get -2 degrees of camber.
Old Mar 17, 2008 | 08:59 AM
tbonesteak's Avatar
really? hmmm ive heard some track junkies getting their rears to 3.5.....maybe i was trippin??
Old Mar 17, 2008 | 09:36 AM
AllenS2K's Avatar
I am currently sitting on -2 all around if that helps.
Old Mar 17, 2008 | 09:43 AM
tbonesteak's Avatar
i need to get my rears to about -3.5 im assuming..... is that possible?
Old Mar 17, 2008 | 11:12 AM
JawKnee's Avatar
I have KWV3s on my AP2 and for whatever it's worth, the least amount of negative camber I could get in the rear was -2.3 or so. Unfortunately, I don't know what the max was.
Old Mar 17, 2008 | 11:44 AM
plokivos's Avatar
i've heard on ap1
front -2.5
rear -2.8
Old Mar 17, 2008 | 01:14 PM
xman03's Avatar
[QUOTE=JawKnee,Mar 17 2008, 11:12 AM] I have KWV3s on my AP2 and for whatever it's worth, the least amount of negative camber I could get in the rear was -2.3 or so.
Old Mar 17, 2008 | 01:18 PM
WashabiS2K's Avatar
I'm running -2.3
Old Mar 17, 2008 | 01:32 PM
Sinji's Avatar
ive had my rears max out at 3.5 dialed it back to 2.5 when I went with a less aggressive tire.
