negative effects widebody kit
Old Jan 14, 2008 | 01:32 PM
dukeykun's Avatar
Default negative effects widebody kit
i was just wondering if applying a widebody kit would actually have negative side-effects on the suspension system (stock/aftermarket) on the S. I heard that the increased offsets will acutally cause strain to the suspension and increase the rate at which you might have to replace it.
thanks for your input and help!
Old Jan 14, 2008 | 01:47 PM
neveronlines2k's Avatar
I dont see why running a lower offset would ruin anything? As long as you have enough room to clear brakes and no rubbing issues anywhere I dont see a problem
Old Jan 14, 2008 | 01:49 PM
SpeedxRacer's Avatar
Im sure he is referring to the hub and bearings.... and to answer the question it does have a negative effect on reliability of those parts, but nothing to the point of noticing
Old Jan 14, 2008 | 03:34 PM
nightcrawler7188's Avatar
you will be placing more stress on your diff and slowing your car down with the wider wheels required by widebody kits.
Old Jan 14, 2008 | 04:25 PM
RED MX5's Avatar
In addition to what SpeedxRacer and Nightcrawler7188 have said, the larger tires that are typically used will have higher rolling resistance, and the wide body will punch a bigger hole in the air, so it will take more power to achive the same performance level you could achieve without the WB setup. Suspension tuning is also mandatory if you want the car to handle properly after going WB. It's something I'd only consider if the car was making so much horsepower that I needed the rubber that the WBK covers, then the WBK would be appropriate. Otherwise, it's just bling, and will reduce both the cars performance and its reliablity.
Old Jan 14, 2008 | 04:29 PM
only do it if you're turbo.
which one are you looking at?
Old Jan 14, 2008 | 04:57 PM
HankookS2K's Avatar
tracy sports ftw!
Old Jan 14, 2008 | 07:10 PM
KnowledgeIsPower's Avatar
if you can afford the bells and whistles of a WBK i would think suspension prematurely failing would not impact your financial standing toooo much?
Old Jan 14, 2008 | 09:50 PM
dukeykun's Avatar
thinking about going turbo within 2 years
i have a busted fender and i was thinking i might as well consider a near future wideboy setup but had to do my s2k homework first
thanks for all the input this is helping me out a lot guys
Ajval79
Jun 21, 2014 03:13 AM
mambo
Mar 10, 2014 04:26 AM
razzele
Jul 11, 2009 02:16 PM
Corleone
Aug 11, 2004 03:05 AM
cjb80
Jul 3, 2001 05:12 PM
