New Redline has been reached with stock ECU
You're not really reaching a new redline (which is marked on the tach as a little less than 9K), you just ran it to the fuel cutoff, which is slightly past the redline as indicated.
How did you get a number so exact? Do you have a V-AFC?
I accidentally did the same thing as the guy with the beemer. I downshifted into 2nd instead of 4th but didnt give it gas while downshifting. I saw the rpm was ok when it happened but when I gave it gas it shot up really fast into redline and then the gas cutoff. So basically I think I downshifted into second at way to hi a speed then the rpm looked fine or hesitated for s plit second until i gave it gas then it shot up like that. Did I damage my engine or valves?
