cdelena,
Ahhhh...those shocks are awsome. They are the ride height ride firmness adjustable Koni's...good job, I love those shocks. Thanks for posting the pic... |
Chris,
These are the stock body specs. You should be able to calculate exactly how much the car is lowered now. Units are mm (inches). http://albums.photopoint.com/j/View?...nce=0&res=high |
Originally posted by Luis These are the stock body specs. You should be able to calculate exactly how much the car is lowered now. Units are mm (inches). Looks like you guys have a good feel for how it should appear.. it IS lower than the .75 inch I was shooting for. I can only guess that the machining of the Koni |
Originally posted by cdelena Originally posted by Luis These are the stock body specs. You should be able to calculate exactly how much the car is lowered now. Units are mm (inches). BTW, my car has never been exactly level (I saw that some time ago before anything was changed) and now I think the right is probably .2 inch lower (it seems most cars are off a little and I always assumed it was normal variances). |
[QUOTE]Originally posted by LATEOTT
Wouldn't it be cool if, upon sitting in the driver seat, your car dropped 0.2 inches on the left side? ;) |
Chris... nice work on the Koni's! You're going to love the ability to adjust the balance. I've noticed that front rebound is the most sensitive adjustment. I use compression only when there is a less grippy surface, then I drop a little compression out of all 4. Rear rebound really affects corner entry, while front rebound really affects corner exit. I've been tweaking ours for quite a bit now, so if you have any specific questions while you're sorting them out just email me! In the meantime enjoy your improved handling! :D
[QUOTE]Originally posted by cdelena
Originally posted by LATEOTT Wouldn't it be cool if, upon sitting in the driver seat, your car dropped 0.2 inches on the left side? ;) Mine is pretty well balanced with the exception of the right rear fender. It's higher a few milimeters than the rest of the corners. I guess it's all within tolerances. |
Just a quick report on the Koni adjustables.. a success! Got the alignment done and have a little time to fool around with street tuning.
These are cool! Very easy to dial in thus far.. and the changes are obvious. Started with all on full soft, and then increased compression until it was too hard for the street, and backed off a bit. Then went to rebound and kept adding control and it feels great.. need to find where rebound is too much and then ease off but traffic is interfering with my tuning! (the downside to living in the city is no clear track.. so you have to go wailing around in traffic.. I |
