nitrous on stock s2000
Old Dec 29, 2006 | 07:20 AM
tampas2000's Avatar
Default nitrous on stock s2000
Hello all, this is my first time posting here.. i bought my 03 s2k in october and have had this zex dry kit sitting in my garage.. i have not installed it yet because i have been searching to see if anyone else (other than those with built motors)have ran nitrous..so far no luck.
so my question is is there anyone out there that has installed nitrous on a stock s2k?
is this a good or bad idea?
thanks for the help
--TPAs2k
Old Dec 29, 2006 | 07:46 AM
Kyushin's Avatar
Banned
From what I have heard the nitrous systems are alot of extra heat and strain on the engine. Personally, i would not use one of these things at all because I dont want to have an engine rebuild in the future. How much of a shot are you planning on using? Im sure some of the pros will chime in shortly and correct my imput if i am wrong, but seens nitrous is risky power.
Heres a link to some impressions on a nitrous system
http://forums.s2ki.com/forums/index.php?showtopic=86045
Old Dec 29, 2006 | 07:51 AM
05berlinas2k's Avatar
i think i have heard it is safe with a small shot and the right tuning???
but like Kyushin im not positive and im not a PRO!! so wait for the pros to chime in...
Old Dec 29, 2006 | 08:06 AM
tampas2000's Avatar
it would be a 55 shot .. i have had nitrous on other cars in the past... i am just concerned with how the S will react to it
Old Dec 29, 2006 | 08:14 AM
s2kshift9k's Avatar
just run a 200 shot you will be ok
Old Dec 29, 2006 | 11:28 AM
s2k dre's Avatar
dont waste ur time with a dry shot, 75-80 wet shot is perfecly safe if u know how to use it, i've been using nos for a long time so i know what to expect, but a stock clutch on the S might last u a week so thats the first thing u need to upgrade.
Old Dec 29, 2006 | 11:54 AM
neveronlines2k's Avatar
NOS will shorten the lifespan of normal wear and tear items such as valve seals & rings etc.. but how fast depends on the jet you use and the tune. At 55 shot you should be OK
Right now we are running 75 shot ZEX kit on a shop S2K just to make it quicker due to poor compression and bad leadown test results , but we are planning a full rebuild (w/ out nitrous) probably high compression stroker or turbo set up.
Old Dec 29, 2006 | 11:56 AM
s2k dre's Avatar
all depends on how much u use. I've seen friends use 2 bottles a week.
Old Dec 29, 2006 | 04:42 PM
frofro24's Avatar
Nice.
I am a stock nitrous hater. I don't know your plans down the road, but if one of them is rebuilding the engine, go for it. I guess a good rule of thumb is, "all in moderation".
I remember when some lady ran a stop sign and totaled my 90 (h22) Accord, I said to my self, "I should have driven it harder if I knew it was going to end this way".
Old Dec 29, 2006 | 05:00 PM
tampas2000's Avatar
i am no stranger to nitrous.. i have had it on my past 3 cars..
my main concern is the timing.
