Occasionally, stick slips out of 4th
Old Feb 5, 2007 | 03:49 AM
Purple Haze's Avatar
Default Occasionally, stick slips out of 4th
Hi. Occaisonally, about once a week, my stick shift slips out of 4th gear and goes into neutral. What could be the cause of this?
Old Feb 5, 2007 | 07:50 AM
hkspwrsche's Avatar
synchros? Where in Va? They'll prob move this to under hood for more info.
You need a mech to test drive. No offense but, once a week sounds like driver error to me. I'm guessing if it were mechanical it would be everytime or at least a lot more often. Are you accellerating or decel when it happens?
Old Feb 5, 2007 | 08:00 AM
GRUNTS2K's Avatar
Similiar thing happens to me but i pull it out of gear without the clutch is that bad?? I know I know i just feel lazy sometimes
Old Feb 5, 2007 | 08:43 AM
Saki GT's Avatar
There are related TSBs but they are for the earlier cars, not 2006.
https://www.s2ki.com/stor/library/TSB/A00-055/index.htm
https://www.s2ki.com/stor/library/TSB/A01-100/index.htm
Old Feb 5, 2007 | 09:08 AM
So could it be a simple matter of not putting it in 4th all the way?
Old Feb 5, 2007 | 10:04 AM
Saki GT's Avatar
Does it only happen when the transmission is cold? How much throttle are you giving it? Are you typically driving up hill?
Old Feb 5, 2007 | 10:47 AM
It mainly happens when the transmission is cold. Average throttle, level ground.
Old Feb 5, 2007 | 12:03 PM
Boofster's Avatar
Honda Service Bulletin said this may be because of aftermarket transmission fluid or dirty transmission fluid. Solution was to replace with the new Honda MTF. If still happens then you have a problem.
uber02
Aug 5, 2014 07:16 PM
Frez2k
Jul 29, 2010 07:11 PM
Purple Haze
Mar 13, 2009 06:45 PM
McMuffin
South Florida
Dec 27, 2006 06:24 AM
ssanae77
Jan 28, 2002 02:29 PM
