OEM Alarm Problems!!!
Old Mar 3, 2001 | 12:24 PM
sumir brahmbhatt's Avatar
ok here's the story, i get out of my car after comming back from a movie and i park my stook in the garage, close the doors and push the door lock button, but nothing happend!!! nothing happens when i push any of the buttons on the transmitter, and i have tried it with both of the ones they gave me!! any suggestions guys??
Old Mar 3, 2001 | 01:02 PM
Jerry1189's Avatar
get new batteries
Old Mar 3, 2001 | 01:12 PM
JiggaTaOG's Avatar
I also have a problem. When I press the lock button twice it usually locks the car and gives me an alert to say the alarm has been engaged. Now, it doesn't give me the alert so I don't know if the alarm is engaged. Did I accidently push a combination of buttons to deactivate the alert? How do I reverse it?
Old Mar 3, 2001 | 01:27 PM
Utah S2K's Avatar
If any door is open (or ajar) you cannot lock the doors with the transmitter. The doors do not lock or unlock with the transmitter if there is a key in the ignition
1) Press the lock or unlock 5 or 6 times to reset the transmitter.
- If the locks now work the transmitter is OK
- If they don't work go to 2
2) Open the transmitter and check for water damage. If there is water replace the transmitter. If not go to 3.
3) Replace the transmitter battery with a new one and try to lock/unlock 5-6 times.
4) If it works transmitter OK if not go to 5.
5) Reprogram the transmitter.
If you get to step 5 email me offline and I'll tell you how to re-program the transmitter.
Old Mar 3, 2001 | 02:44 PM
Utah S2K's Avatar
Sumir....you have mail......
Old Mar 4, 2001 | 06:41 PM
Siepel's Avatar
Also, make sure the Valet mode isn't accidently switched on!
Siepel
Old Mar 4, 2001 | 07:15 PM
S2K Fan's Avatar
Did it work fine before?
Old Mar 5, 2001 | 08:18 AM
Red_s2k's Avatar
My Odyssey had a similiar problem... I finally noticed one of the buttons stayed stuck in. The clue was that the lite did not light when a key was pressed. I had even replaced the battery for it. Also the horn chirp can be changed from on to off with a combination of key presses, look in the manual.
Old Mar 5, 2001 | 11:18 AM
valet mode? how do you turn it on/off?
i tried resetting the code, but sigh it didnt work i may be doing something wrong. and when i press the buttons the light does come on. i may just end up giving it to the dealer.
Old Mar 5, 2001 | 11:25 AM
ricosuave's Avatar
check your transmitter's led light to make sure your batteries work.
