OEM front lip and small flaps??
Old Jun 21, 2004 | 11:32 AM
tjohn's Avatar
Default OEM front lip and small flaps??
K, my neighbor and I are attempting a front lip install tonight. You know those small flaps under the front bumper (in front of the tires).... should they be removed? I don't like the way they look to begin with and it looks like they'll still show below the OEM lip. Has anyone removed them? And if so, how do I remove them?
Thanks, pics to come after lip install even though it's nothing special
TJ
Old Jun 21, 2004 | 11:38 AM
Bass's Avatar
No you do not need to remove the flaps to install the lip-
i beleive they help keep the car stable at higher speeds
if you want to take them off they are just screwed in
Old Jun 21, 2004 | 11:43 AM
tjohn's Avatar
Keep the car stable at higher speeds even with the lip installed?
Old Jun 21, 2004 | 12:27 PM
natedoggs2k's Avatar
YES!
Keep them.
Old Jun 21, 2004 | 12:47 PM
Elistan's Avatar
1) They can easily be removed by undoing two screws each. Look under the car and they're easy to spot.
2) There's no need to remove them to install a front lip.
3) The flaps provide significant aerodynamic benefits by redirecting the air around the tires. My personal opinion is that an S2000 that does not have them looks like it's been damaged in an accident. (They get knocked off every once in a while but road debris.) Performance at higher speeds will likely suffer.
Old Jun 21, 2004 | 02:11 PM
tjohn's Avatar
Thanks for the replies! All done, left the flaps. Pics below.
Old Jun 21, 2004 | 02:13 PM
wanabe's Avatar
the flaps are called "strakes"...
and the purpose is as indicated above-
i would not remove them unless you never plan to drive fast...
and if thats the case-
time to trade that baby in!
btw, lookin good!!
Old Jun 21, 2004 | 03:14 PM
tjohn's Avatar
Thanks wanabe It was pretty easy!
Old Jun 21, 2004 | 04:22 PM
Hey, that looks like my car!
Old Jun 21, 2004 | 04:40 PM
allkingz's Avatar
TJ
If you can still see the strakes in front of the wheels even with the front lip installed, your car isn't low enough.
