OEM Seats
Old Jun 21, 2006 | 11:50 AM
doheboy6's Avatar
Default OEM Seats
Hi,
I just got back from my lunch and was curious to see if the passanger side seat would directly fit onto the driver side. Would I have to switch rails or is it just a direct switch?
P.S., my driver seat is getting a little worn so I want to slow down it's process by swapping seats.
Any help is appreciated.
Thanks, David.
Old Jun 21, 2006 | 12:26 PM
cdelena's Avatar
It is my understanding that they are not interchangable, but if you come up with a workable procedure please post it.
Old Jun 21, 2006 | 01:56 PM
doheboy6's Avatar
Roger.
Old Jun 21, 2006 | 02:03 PM
Ks320's Avatar
I believe the bolsters are interchangeable ...
Old Jun 21, 2006 | 02:31 PM
nightcrawler7188's Avatar
i think they would be, but you wouldn't be able to get to the tilt lever on either side.
Old Jun 21, 2006 | 06:22 PM
DerrS2K's Avatar
perhaps just swap the covers as I don't believe the rails and seat belts will line up
Old Jun 21, 2006 | 06:44 PM
coxjajb's Avatar
I swapped the bottom cushion with cover from the passenger side to the drivers side. It was a simple process. It was a direct fit. I didn't try the back due the seat belt loop.
Old Jun 21, 2006 | 08:22 PM
klee1113's Avatar
care to post some instructions?
Old Jun 22, 2006 | 07:23 PM
coxjajb's Avatar
I removed the seats from the car. The bottom cushions are attached to the frame with a couple of bolts. I can't remember if there is bolt per side or two. Remove the bolts and the cushions come right off. Switch sides and re-install the bolts. That's it.
Old Jun 22, 2006 | 09:02 PM
Somehondaguy's Avatar
Did it look funny having the worn one on the otherside?
can you post pics of the new passenger side? wanna see what that seat having a worn left bolster looks like
