The oil change from hell
I wonder what it is about the S2000 that causes mechanics to leave the oil cap off? I took mine to a Honda Dealer for the last oil change and they left the cap off. When I got in the car I noticed more induction noise. I thought they had left the air cleaner cover off. When I got home and checked, there was oil all over and no cap. Luckily, the mechanic left it on the black sill on top of the fire wall so I didn't have to hunt all over for it.
Originally posted by SanMarinoCpe
From a dealership point of view, when you took the car in for service did you explain that an oil cap was missing from a previous service and that you replaced it? If the answer is YES then it is a misdiagnosis from the dealer and the transmission should of never have been pulled. If NO then you have a fine line of who should pay for the transmission being pulled out. This is a pretty common problem and we have seen a few of these situations before with missing oil caps.
Originally posted by asmx
The more I think about it the more it becomes clear that it should not have cost $700
I am not sure why they are telling you there was no way to get it out. I would have to check to see how many but I think it might be 6 times we have seen this and of the 6 at no time did we need to pull the trans out. It sounds to me like they have never come across this before and desided to pull the trans to service it. They are quoting book time which should not be used in this case. I would bet the trans never came completly out of the car. JMO
Make the dealer show you the flat rate time in his book. I believe the book time for R & R clutch is about 5 hrs so just to R & R transmission (which you must do to replace clutch) should be about 4.5 hrs. Or call another dealer and get charge for R & R transmission. I think dlr. is ripping you (or the service station) off.
If you want to get realistic. when removing the trans you drop the front cradle 3.5" to access the top bolts on the trans which is far as you need to go to get a stuck oil cap out which probably hit the ground by then. Labor to do that should be between 2 and 2.5 hrs. If you still have a problem with the dealer call 1-800-999-5901 and submit your complaint
ing shoot him. stupid mother
