Oil usage - Should it use this much?
I have a 2003 S2000 with 6k miles. The oil usage has been faily low until recently. I check everytime I fill up with gas (just like the manual states). The oil was changed last at a Honda Dealership, and I have topped it off with either Penzoil or Castrol GTX.
Last week it used about a quarter quart between fillups. (1/4 quart)
This week it used about a half quart between fillups. (1/2 quart)
Is this a sign that there is something is wrong or is this fluctuation like ones you guys have seen. A little worried because I have never owned a Honda that drinks oil like this.
I have checked for leaks (none). I Vtec daily, but not obsessively. Just usually driving my 10 mile commute to work.
I have found that the oil usage is not consistent over fairly short distances, like one or two tankfuls. There may be no drop, and then suddenly a drop of a couple of x's on the stick. Over longer periods, it is much more consistent, and I can reliably predict that after 2500 miles or so, I will be right about needing a quart. Sorry to say that 18,000 miles has not resulted in a drastic decrease in this consumption level, which is pretty much now what it was when the car was first delivered. It is evidently neither excessive nor abnormal, and I can definitely live with it.
FYI - You should top off with the same brand oil. Foaming could occur coz of the different additives.
You got yours changed at the dealer. I think the honda oil is rebagded Mobil Oil. not sure. Get an extra 2 Quart when your at the deal for the oil change.
I use my '03 as a daily driver. It has 18,000 plus miles of mixed highway and stop and go driving. I average about 25-26 MPG and use about 3/4 Qt. of Mobil1 oil every 3000 miles. Other member's cars will vary according to the car and usage type. -Ken
I bought my MY00 with 29,000 miles. After 3000 miles the oil level did not change. I changed to synthetic oil and it started using oil pretty darn bad. Just like it started using oil it stopped with no further consumption. I now have about 37,000 and it never needs any topping up.
While most of my driving is on the interstate I do get in some pretty bad traffic jams routinely. I also ran a few autocross races in it.
Elliott
Elliott
