one really hot hot tire
i've been noticing that something in the rear of my s2000 has been smelling like its burning. it smells like plastic is melting or that glue gun smell. i've looked around and don't see anyting. i have noticed that one of my tires gets very hot. like the polish lip portion is super hot. What could cause one tire to heat up more than the others? the pressure are all hte same in all 4 tires. Anyone else have this problem. the smell is pretty strong but i cna't really tell exactly where its coming from.
This happened to my pickup truck before. After a long drive I've noticed that one of the rear wheels are super hot. Hot enough that when I sprayed water on the wheels it sizzled. Problem was the brake pads were sticking. Pads where not returning back to floating position. Solution was to overhaul brake pistons and new pads.
I've had a caliper seize up on this car. The rim gets extremely hot, so does the tire. Smells very bad (try not to inhale it, brake dust is extremely bad for you). Simple rebuild of the caliper and regreasing the slider pins solved it.
Originally Posted by ihavenosn16,Jun 15 2007, 02:06 PM
there is plenty of brake life left and i havent had any problems at all with the brakes.
Most likely it is the wheel that is getting hot and not the tire. Could be a dragging brake, could be a bad bearing. Dragging brake is a pretty common automotive failure.
