Opinions
Old Apr 2, 2001 | 06:34 AM
sweetj's Avatar
What is your input on the Pirelli SS 7000 or the Toyo T1S for rear tire replacements?
Old Apr 2, 2001 | 09:15 AM
Unicron's Avatar
sweetj,
Both tires are going to be alot more narrow than the S02's.
But, if I had to choose...
Go for the T1-S. Good dry and wet weather grip.
P7000 Supersport should last a bit longer...but not by much.
Old Apr 2, 2001 | 09:54 AM
Chiman's Avatar
The P7000 Supersport are really noise. I had one on my A4, and the car sounds like a train at speed above 70mph.
Don't know about the Toyo
John
How about the RE930?? About the same price?
Old Apr 2, 2001 | 11:30 AM
sweetj's Avatar
Unicorn,
If I was to get the Toyo T1S, what size should I get them in?By getting the Toyo's I would save about $90. Do you think it's worth it? I'm worried if I switched I would lose the traction that I have with the SO-2s. Would switching make that much of a difference? I also use my car as a daily driver, 30miles each way to work. It's half highway half city. Any other suggestions are much appreciated.
Old Apr 2, 2001 | 11:38 AM
Brett's Avatar
I put the Toyo T1S on my 1982 Porsche 911SC and they were great tires. But I had some old Pirelli 7 series on it before so maybe the Toyo seemed better than they were by comparison only. I don't know how they'd fare on the S2K, but from what I remember, it improved the handling on my 911 immensely.
BC
Old Apr 2, 2001 | 12:46 PM
Unicron's Avatar
sweetj,
I would get the 245/45/16 T1-S for the stock rears. They have the same diamter as stock (24.8 inches).
http://www.toyo.com/tires/tire_lines/high_.../specs/t1s.html
Let me compare my 245/35/18 T1-S to the stock...
I would guestimate that the T1-S have 3/4 the grip of the S02's. I can launch @ 7K with the S02's where 6K is all I can launch the T1-S at. The S02's have a stiffer sidewall than the T1-S. There will be a difference in road holding without the S02's.
With the S02's, I can take corners a bit faster...but the S02's seem to give out without warning (behave like R compounds). I like the T1-S because you can hear the tires sqeal before they loose road holding.
But, the T1-S has lasted me double the milage than the S02's and the T1-S is alot better than the S02's in wet weather.
If you want max performance, short-medium tread life...S02's.
If you want between max and medium performance, long tread life, good wet weather handles...T1-S.
Old Apr 2, 2001 | 12:58 PM
cdelena's Avatar
A word of caution.. having a different type of tire on the front and rear will alter the handling of the car, especially when pushed towards the limit. It may not may a difference for most drivers, but it can provide some surprises.
The Toyo
Old Apr 2, 2001 | 01:36 PM
warpspeed's Avatar
I've got 255/35/18 Toyo TS-1s and love them!
Old Apr 2, 2001 | 02:35 PM
Unicron's Avatar
cdelena,
I worded my post wrong...but I am pretty sure that the 225/50/16 S02 sidewall is stiffer than the 225/50/16 T1-S sidewall.
Old Apr 3, 2001 | 04:26 AM
sweetj's Avatar
So, I have decided to give the Toyo's a try. Is it best to get the 245/45/16 T1-S for the stock rears? Would this size be most comparable to the stock SO2?
Chubbikin
Feb 7, 2005 06:55 PM
Wisconsin S2k
Jan 31, 2005 12:37 PM
s22k
Nov 12, 2002 12:46 PM
UCrazyKid
Aug 23, 2002 09:59 AM
str8 6
Feb 1, 2002 04:58 AM
