Ordered 4.77, V2, V-AFC + Direct Port Nitrous kit
Hopefully by the end of the weekend I'll have my spugen 70mm exhaust w/ straight pipe ordered. I am looking to turn some good numbers but we'll see.
Wet kit direct port
1)Got an V-AFC cant afford EMS right now(Is this needed doesnt zex control ur AF ratios)
2)Bottle valve opener
3)Bottle gauge
4)Purge kit
5) MSD Window switch
6)Bottle heater
I just need colder spark plugs dont know which one to get
Heh im hopping for high 12's.
Wet kit direct port
3)Bottle gauge
4)Purge kit
6)Bottle heater
Originally Posted by S2Kreative,Feb 27 2006, 09:41 AM
you mean safer right? jk.. good luck with the set up,,you will def have a quick car for a while!
I'm going to get it tuned so its safe. I wont go up and down 495 spraying. I will prob spray once every two weeks at the track or if im doing runs for fun with my friends.
Heh everyone watches too much F&F and thinks is 100% unsafe. I am going to get my car tuned for it. S2k will love nitrous its 11:1 compression + forge internals will thrive on it. I also will have my Air Fuel Ratio adjusted and timing retarded. Its not like im gonna go around spraying every day of the week. I got this for track use or weekend street run use.
I like that thats Actually my plan except I'm getting my 4.44 in a few weeks installed on my S...
I guess you have to really experience with nitrous before you can say thats its dangerous and forbiden
LOL......But I can say I used it first on my last civic, I went trough about 23+ on 50 shot and about 3 on 75shot of wet NX bottles and that was without being safe...on a 1.7 SOHC Civic.. I ended up blowing the Headgasket which it wasn't a surprise pushing about 210 WTQ on that stock weak engine so I guess the S2000 will do a lot better taking the right precautions like colder plugs and checking you A/F ratio...Good luck...
D.
LOL......But I can say I used it first on my last civic, I went trough about 23+ on 50 shot and about 3 on 75shot of wet NX bottles and that was without being safe...on a 1.7 SOHC Civic.. I ended up blowing the Headgasket which it wasn't a surprise pushing about 210 WTQ on that stock weak engine so I guess the S2000 will do a lot better taking the right precautions like colder plugs and checking you A/F ratio...Good luck...D.
D.
Colder plus + V-AFC should take care of that. I also got the ZEX kit which is suposse to be idiot proof.
