painted calipers
Old Oct 22, 2005 | 05:07 PM
Panda's Avatar
Default painted calipers
What kind of paint did you guys use to piant your calipers?? Where did you guys get this paint??
Old Oct 22, 2005 | 05:14 PM
Silver9k's Avatar
G2 from decal girl
Old Oct 22, 2005 | 05:40 PM
spider2k's Avatar
Active Streak: 30 Days
i bught mine here. 31.99 shipped and had it in 2 days.
Old Oct 22, 2005 | 06:26 PM
Hockey's Avatar
G2 all the way. That is a good price, but decalgirl also has the S2000 decals so you can get them both at the same time and save on shipping.
-Hockey
Old Oct 22, 2005 | 06:43 PM
Idyfohu's Avatar
G2 eBay Auction and Decals from Decal Girl!
Actually just got done paintin them and will post pictures tomorrow. Black Decals on Red Calipers on Black Car.
Old Oct 22, 2005 | 07:25 PM
Emil St-Hilaire's Avatar
Tremclad Rustproof hightemp=$3.00
Any color you want.
Old Oct 22, 2005 | 09:35 PM
Boneyard's Avatar
autozone 20$
Old Oct 22, 2005 | 09:37 PM
SilverKnight's Avatar
pep boys
Old Oct 23, 2005 | 02:24 AM
Jason B's Avatar
Pasting my write-up again.
This Project took me about 3 days total. This mod is not difficult, but is a little time consuming and tedious if you want to ensure a quality job.
Some have chosen to grind down the casting marks on their calipers before the G2 system and others have not. It looks good either way and is a personal preference. It all depends on how much time you want to spend. If you want your calipers to look smoother like a profressional powder coat job, then you should grind. Grinding will give you that "Porsche" smooth factory caliper look.
The materials used are as follows:
- G2 caliper paint kit. Red = $31.00 on sale (www.decalgirl.com)
- Bright silver metallic "S2000" logos = $11.99 (www.decalgirl.com)
- 2 3/4' wide Artist brushes = $2.99 each (Ben Franklin crafts store)
- 1 small pointed Artist brush (for more detailed/hard to reach areas) = $2.99 (Ben Franklin crafts store)
- 1 Sunday edition Hbg Patriot Newspaper = .50 cents (QT)
- 2 Hefty Trash Bags = .05 Cents (Walmart)
- 1 Dremel #953 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 Dremel #932 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 BrakeKleen Brake Cleaner = $0.00 (Included in G2 caliper paint kit)
- 5ft. standard Masking Tape from your basement = Free
Tools used/optional
- Die grinder with wheel. This is a fast and easy way to remove those casting marks in SECONDS! You need to be very careful if you use this tool because if you press too hard, you can ding the metal. If you don't have one of these, then the Dreme grinding stones will do the same job, but will take longer. (borrowed from neighbor).
- Generic dremel tool. = $9.99 with 60 attachements. (Harbor Freight)
- Sanding drums- came in the 60 piece attachment kit above, fit any hand/dremel tool.
Safety
- WEAR GOGGLEs and a MASK when grinding! You don't need metal fragments in your eye or in your mouth!
PICTURES!PICTURES!PICTURES!PICTURES!PICTURES!
First, get your car up on jackstands. For best way to get your car up on jackstands, read the 2nd post here
Picture of my front caliper FULLY grinded down in all visible areas and smooth as glass. (5+ hours total for all four calipers over two days.
I put about 6 coats of G2 on the fronts and 4 on the rear. Instead of mixing the full amount of paint and reactor in one shot, I took 4 parts of paint using a plastic spoon, and 1 part reactor on a spoon into a small can. This small amount let me do 1 coat on all 4 calipers. I then, repeated the above until I got mutiple coats. I probably have enough left over to do one more coat on all the calipers. I'll save it for touch up down the road. If you mix it all at once like the instructions say, you will only have about 3 hours working time before the paint is hard and unusable.
Picture before logos:
Picture after front logos:
I did not put logos on the rear. To my eye, it didn't really look as balanced and I only favor them on the front - they look like they are made to go there....
Some full shots:
A big thanks to StknCaS2k, Virus, enzyme, Hockey, ruexp67, Johnny--2K, KenGPW, and others
Old Oct 23, 2005 | 02:27 AM
I did both, it just didnt look matched up if i only did front
