Passenger Door and rear panel damage
Old Nov 27, 2007 | 11:32 AM
ta845's Avatar
Thumbs up Passenger Door and rear panel damage
My car's passenger door and rear panel were scraped while parked. The body shop needs to remove part of the convertible top to paint the two panels that need repaired. I am concerned that removing the top could cause problems in the future.
Should I be concerned about this? Anything I should look out for? Is it easy to remove the top then reinstall it?
Thanks
Old Nov 27, 2007 | 02:53 PM
jelliotlevy's Avatar
Thanks
You have to let them do whatever is necessary to accomplish the repairs. If you limit what they may do, you cannot complain if the work does not come out right. When you get the car back, I would immediately put the top through several up and down cycles to verify its correct operation. Many moons ago, I had a VW 412 wagon (weird rear engine design) with minor body damage in the rear. The shop had to do a lot of disassembly of engine plumbing to pull out the dent. When I got the car back, it began misfiring after just a few miles. Turned out that two of the four spark plug wires had not been securely re-inserted. After that fix, all was o.k.
Old Nov 27, 2007 | 03:40 PM
J'sS2K's Avatar
Which part do they want to remove?
Old Nov 27, 2007 | 05:34 PM
MikeyCB's Avatar
I had my rear quarter replaced and they had to remove the soft top for it. Get a knowledgeable shop and you'll be fine.
Zerolagoon
Feb 10, 2016 08:46 PM
phongs2000
Sep 28, 2015 07:02 AM
MikamiD
Feb 15, 2007 06:08 PM
s2krazy01
Jan 24, 2006 07:16 PM
