Passenger Window won't work
Old Dec 25, 2006 | 08:33 PM
HankookS2K's Avatar
Default Passenger Window won't work
Im installing a 530t window module so i can get one touch up and down on both windows. To get your passenger side switch to have one touch you have to interface the wires to your passenger side up and down wires and those are at the passenger side kick panel.
Well i cut the wires and connected them and the one touch down worked perfectly fine. then they wouldnt roll back up. I reconnected the wires back to the factory wires and now the passenger switch doesnt work at all! no relay clicks or anything, but when i try using the master switch i hear the relay click only when i press it down and when i pull it up i hear nothing.
Anyone have any suggestions besides the dealership?
Old Dec 26, 2006 | 11:23 AM
an_other's Avatar
Check the fuses in the engine bay. I had a similar issue, and a "big blue square" fuse had gone bad.
I apologise for being vague. I'm on vacation with little access to S2k stuff. Good luck!
Old Dec 27, 2006 | 08:58 AM
HankookS2K's Avatar
found out the problem...took it to the honda dealership and they told me there is a short in the master switch. Because the passenger switch gets all its power and signal from the master switch that is why it wouldnt work but the driver side would.
They quote me 130 dollars for a new master switch and 180 dollars for labor to put the switch in and plug it in...WHAT A JOKE! Will be looking on the internet for a switch cheaper. No hurry anyways my car is in the shop getting a new AP2 BUMPER painted!
sexysilvers2000
Sep 4, 2018 04:01 PM
WhiteLite
Feb 6, 2014 03:30 PM
MIP
Jun 13, 2009 02:33 AM
Chitah831
Aug 16, 2003 04:28 AM
