Please Help: NOS system not working on S2000?
Roku - Please explain why you drilled the CAM COVER?
Nitrous Oxide is a gas you inject into the intake tract at a common point. I would assume you would remove the intake manfold and drill/tap it. Or possibly the throttle body.
I can't imagine why on earth you would drill the cam cover.
Got any photos (and I don't mean of your flying dog)?
K you have it hooked up in the wrong place... horribly wrong.
Dry System - The nozzle is installed in your intake tube. It then turns the nitrous into a gas as it is sprayed into the air stream.
Wet System - nitrous and fuel are sprayed into the air inlet thru a nozzle.
Port System - nitrous and fuel are jetted into the intake ports thru individual nozzles (equal amounts of nitrous distributed to each cylinder)
Originally posted by alexf20c
So then what are these:
http://www2.freepichosting.com/Images/140536/0.jpg
Is that an air horn?
ITB's silly!
Let me draw you a picture.
