Problems corrected by TSB resurfacing?
Old May 28, 2001 | 10:34 AM
s2kmtl's Avatar
Hi
After 15000KM I had my transmission replaced due to 1-2 crunching/finished clutch. I must admit, I kind of abused the clutch a bit by doing a few 6500 RPM clutch drops but since getting everything replaced I never did a 6500 RPM clutch drop.
I am now at 35000KM and I am having the following symptoms:
1-2 grind (any RPMS) 40% of the time
4-5 grind (higher RPMS) 60% of the time
This really sucks.. Any ideas? Anyone have the same problems? I drove my CIVIC and my TYPE-R just as hard if not harder and never had a problem like this.
Thanks
Rob
Old May 28, 2001 | 10:51 AM
cdelena's Avatar
I have exactly the same symptoms although maybe not as often, and I have had the TSB work done. They only happen when the gearbox is hot. The 1-2 grind is especially irritating because it happens pretty often on the street. The 4-5 grind only happens at high rpm (just about every lap at TWS) and I have just slowed down the shift to reduce the frequency. It is frustrating and I have not decided I want to go through another year long conversation/disagreement with AHM.. so I am just living with it for now.
Old May 28, 2001 | 10:53 AM
s2kmtl's Avatar
I double clutch for 4-5th now
I am trying to get the courage to start another scrap with Honda Canada because I know I will get flack.
Rob
Old May 28, 2001 | 11:12 AM
Sev's Avatar
Sev
Rob
Knock on wood, my 4-5 is fine.
As for the 1-2, any time i try to shift a notch faster then average, khhhhhht and after that it happens more often untill i let the car cool.
Old May 28, 2001 | 11:46 AM
cthree's Avatar
Administrator
I'm getting my TSB work for the syncros and the clutch done on Tues. No 4-5 but the 1-2 is a pain in the ass.
I've also started to notice a click/clunk/creak from behind my right ear. It happens most often when I start from a stop, come to a stop or alternately punch and release the throttle in 1st at very low speed. I hope my diff isn't screwed. It seems to be getting worse.
Old May 28, 2001 | 03:57 PM
mulot30th1's Avatar
The infamous 1-2 grind happens every most innoportune time
Old May 29, 2001 | 01:57 PM
SUis1's Avatar
I'm in for the second time on the 1-2 grind. The regional rep told me they were aware that there were still problems with a small percentage of cars after the first fix. It seems that if the fix was done early, as was mine, Honda may have come out with a slightly differant set of parts. I think what he was tring to say is that Honda took out bad parts and put new bad parts in. Supply chain problem.
We'll see what happens.
Old May 29, 2001 | 03:17 PM
sage's Avatar
Is this, 1-2 tranny grind something Honda has fixed in the 2001 model?
Old May 29, 2001 | 03:29 PM
fly n low S2K's Avatar
hi im new to this site,what is TSB i have 01-S2K built in March 01,will this effect me thanks.
Old May 29, 2001 | 03:30 PM
Phantom's Avatar
s2kmtl,
I don't think that dropping the clutch at high rpm's encourages the 1st to 2nd gear grind.
[QUOTE]
