S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   Proper Replacement Key (https://www.s2ki.com/forums/s2000-talk-1/proper-replacement-key-1190399/)
Bjehle Dec 16, 2018 07:11 AM
I got this AP1 with 1 key (black) and a remote for the factory keyless (72147 S2A A01).
There are 5 part #s for S2000 keys:
35111 S2A 306 -157$
35114 S9A A01 -22$
35113 S9A A01 -28$
35113 S84 A02 -48$
35114 S84 A02 -42$
Obviously the 157$ one is the master key but can one of the cheaper keys be used as a master?
Deckoz Dec 16, 2018 07:48 AM
This is the part number I used as master
https://cimg7.ibsrv.net/gimg/www.s2k...828fcaca1.jpeg
https://cimg9.ibsrv.net/gimg/www.s2k...bb799b6847.jpg
Bjehle Dec 16, 2018 08:00 AM
35113 S84 A02 thanks Deckoz
Deckoz Dec 16, 2018 08:11 AM
NP, btw im pretty sure the 157 key is exactly the same - except comes with a new immbilizer ID that needs to be programmed into the ECU.
The others are cloner keys - ie they rock a clone of your original keys immbilizer.
not saying this happens, but, you can technically get new keys with new immbilizer IDs, and remove the old ID's so if say a previous owner didn't give you all of the keys, it effectively disables the old keys out in rhe the world.
Bjehle Dec 16, 2018 10:07 AM
Ok now I understand the process, that makes perfect sense.
Do you know if it has to be a dealer to program the 35111 S2A 306 or can the tech next door with a snap-on scope do it?
Deckoz Dec 16, 2018 11:23 AM
Tech should be able to clone a key without the car
Honda has to program new immobilizer ids, and it requires the car.
Say Chi Sin Lo Dec 16, 2018 08:55 PM
Can you pair a Honda keyfob to an aftermarket (Viper) alarm? I too only have one key and the car had Viper alarm installed... thank you all!
Deckoz Dec 17, 2018 04:40 AM
No. You can order viper fobs on their own though.
Say Chi Sin Lo Dec 17, 2018 07:22 AM
Ok thanks, do early 2000 AP1 have chipped keys? Or they're just traditional keys and any locksmith can copy a key for me?
Thanks!
Deckoz Dec 17, 2018 08:26 AM
Thanks!
All s2000 are immbilizer chipped. Honda dealership should only charge you the cost of the key($45). They put your key in a machine which powers the chip so the code can be copied to the new cut key
© 2026 MH Sub I, LLC dba Internet Brands
