Psst, Krazik, in here
You made this whole affair public, so I thought it appropriate to post this here. UPS Tracking number, as promised:
1zw4973x039953098
If you check it before 7-8pm, it will come up invalid, but it should be in the system shortly there after. I insured it for $1000.00. UPS is 4-5 days, which should put it in time for Thanksgiving. Remember, before installation, you need to wipe the entire thing down with rubbing alchohol. I did not bother cleaning it up because it will get fingerprinted anyway (hence the recommendation for rubbing achohol), so it's a scant bit dirty. Nothing that won't clean up though. I also enclosed the never installed heat sheild, as well as the new exhaust manifold gasket (I reused the factory one). I would add in a few niceties, but I figure you wouldn't be receptive to them anyway.
1zw4973x039953098
He probably means the instructions and the coveted Mugen Stickers.
I would think you would want an invoice from a dealer... which I think VT is. You might need this in order to get a replacement if the heat-shield thing breaks.
Dan
Dan
[QUOTE]Originally posted by Skarv:
[B]He probably means the instructions and the coveted Mugen Stickers.
finally a resolution to the long thread
