question about installing Aftermarket Exhuast Please HELP!!!!!!! JIC MAGIC exhuast
Old May 13, 2004 | 11:23 AM
23jumpman23's Avatar
Default question about installing Aftermarket Exhuast Please HELP!!!!!!! JIC MAGIC exhuast
i just bought a used JIC magic exhuast(dual) and was told i needed a gasket in between the beggining of the pipe and the catalyic conveter .... i was told to go to honda and get a stock OEM gasket ..... the only thing on there diagram was a exhuast gasket but it was a round piece of metal a perfect circle and was told by the person who sold me the exhuast this is the wrong part ......... soooooo do u need a gasket or not??? if so where can i get one ASAP and what is the part # from honda because the dealership here is clueless, ive had this exhaust sitting around for almost 3 weeks and cant find a solution ..... please help someone
thanks
Old May 13, 2004 | 11:30 AM
speed4tu's Avatar
That is the only OEM gasket avail. I think. The one that is between my test pipe and J's exhaust is like a normal looking gasket. It came with the exhaust tho. The only quick solution I can think of if you don't want to use the OEM gasket, is go pick up some gasket paper from Auto Zone or some place like that, and cut yourself one out.
Old May 13, 2004 | 04:28 PM
Road Rage's Avatar
I have made gaskets and brake shims out of flattened beer cans.
I would agree with going to get some gasket material and cutting your own - trace a template. I would also consider adding some red hi-temp RTV to one one of the surface "faces" to ensure a good fit without leaks. Do not use a lot, and remove any excess after it cures by cutting with a box cutter.
Old May 13, 2004 | 05:02 PM
YOD88's Avatar
why dont you try to call the makers of the exhaust???
they should know since they made and tested the exhaust...
Old May 13, 2004 | 05:10 PM
Russ's Avatar
Any custom exhaust shop could make it for you. I've seen the machine (which does
such work) in action and its quite extraordinary. Fully computerized.
Old May 13, 2004 | 06:22 PM
John_Z's Avatar
I'm running the JIC single without a gasket against the cat, and now a test pipe. Mine never leaked or hissed. Just make sure to torque the bolts evenly to 25ft lbs.
Old May 13, 2004 | 10:43 PM
anyone else pleas help
wojtekj1977
May 4, 2014 05:32 AM
TheCoffeeClub
May 17, 2012 02:23 PM
EpRAnGia
Apr 21, 2009 03:51 PM
s20004lifehomes
Mar 10, 2008 06:26 PM
the fan
Jan 19, 2008 07:24 AM
