question : What happens when you grind the gears
Old Oct 4, 2007 | 06:08 AM
driftintherain's Avatar
Default question : What happens when you grind the gears
when you grind the gear, what will happen to your car?? except for ruining the clutch?
Old Oct 4, 2007 | 06:31 AM
SSSnakeSSS's Avatar
The clutch would be the least of your worries. Grinding gears can chip or break the teeth on the gear sprocket, which could require a transmission rebuild.
Old Oct 4, 2007 | 06:45 AM
Mocky's Avatar
FYI: I edited the title so it lists a specific question.
Old Oct 4, 2007 | 06:57 AM
neoarroyo's Avatar
When you "grind" a gear..you are trying to move another piece with dog teeth on it into the "gear" you are trying to select. Do it wrong and the teeth doesn't match, hence the grind. Check out how your transmission, clutch etc works on www.howstuffworks.com. You'll see what I mean.
Old Oct 4, 2007 | 07:02 AM
thanks
Old Oct 4, 2007 | 07:03 AM
will there be any damage to the engine?
Old Oct 4, 2007 | 07:07 AM
3ngin33r1's Avatar
There could be if you grind them, something breaks and the tranny seizes and the clutch holds sending a massive amount of tweaking torque back to the motor twisting up internals.
Old Oct 4, 2007 | 07:49 AM
than do i have to replace the motor too?
Old Oct 4, 2007 | 07:59 AM
gello2024's Avatar
dont worrie... one time here and there wouldnt hurt... grinding everyday would F it up!!!
Old Oct 4, 2007 | 08:31 AM
Sabre's Avatar
^^ I would be more specific and say that a light grind once in a while is not that serious. Just don't keep trying to force it if it grinds. Nice that your natural habit when it grinds is to cringe and let go.
