Quick Jack failure
Old Apr 29, 2021 | 05:15 AM
  #21
flanders's Avatar
Yeah that is normal, think the manual says do not lift bellow a certain height as well.
Old Apr 29, 2021 | 09:33 AM
  #22
engifineer's Avatar
Originally Posted by Ian300D
Another gotcha I found out. Never drop as low as that picture above. My unit won't raise at all from this stance. It's like the first 1in of lift has zero strength, but rest is fine. I've not done anything to look into this though so maybe not normal.
I believe it says in the manual that there should be 1.5" of free clearance before car contact to lift properly. That is what the owner of the set I borrowed told me.
Old Apr 29, 2021 | 09:37 AM
  #23
engifineer's Avatar
Originally Posted by auric
Same happened to me. Was on my way up when one side gave. I have since "bled the system". I almost always stack tires under the car, but didint this time cause I was doing exhust work.
Was your pic after the incident? I am confused as to why the wheels were off the car before it was lifted and the safety locks engaged. At that point there is no way it would have fallen like that. You have to raise the car to remove the wheels, and you should always raise until the safety engages, then lower until it is sitting on the safety locks (not suspended by the hyrdaulics). Or did you have it up higher and need to lower it some after wheels were removed and then this happened?
Even on a full sized lift, best practice is to lower fully onto the next safety stop so it is not putting constant pressure on the hydraulics. Not that the system should fail like this at all, but much safer this way.
Old Apr 29, 2021 | 06:20 PM
  #24
darcyw's Avatar
when the safety arms are properly engaged, there is no way it will fall down- again, properly positioning and checking the arms is critical. As mentioned above, the hydraulics should never hold the car up- never.
darcy
mark_a21
Sep 18, 2018 05:12 PM
2NDW1FE
Oct 11, 2016 07:22 PM
Rayz_S2K
Oct 11, 2016 06:19 PM
RolanTHUNDER
Sep 26, 2016 03:25 AM
