Quick Question
Old Jun 22, 2006 | 11:40 AM
aussie export's Avatar
Default Quick Question
So I'm going to be picking up a set of OEM wheel locks after work today and want to know if I need to raise my S before removing the lug and replacing it with the lock or can I just leave it on the ground and intall the wheel lock?
[I checked the archives to make sure this wasn't a repost, didn't see anything.]
Old Jun 23, 2006 | 12:55 PM
dmz's Avatar
dmz
Just leave the car on the ground and remove one of the lug nut and replace it with the lock and tighten it to 80 ft-lb of torque.
Also whenever you replace the lugnuts or key locks you should re-tighten them after driving for about 100 miles to prevent them from coming loose on its own.
Old Jun 25, 2006 | 07:02 PM
robert112's Avatar
why are you riskign damaging the thread on your bolt? just lift the car up and do it propelry, the extra amount of work involved is not worth the risk even tho it MAY and probably WILL be perfectly okay it takes an extra 5 minutes to jack up a car if you have half decent arms =]
ryanswhites2k
21
Jan 22, 2014 04:26 PM
goldenfri
Jun 26, 2006 09:52 AM
Panda
San Diego S2000 Owners
Oct 28, 2005 08:20 AM
mikecl713
Dec 10, 2004 09:52 PM
cthree
May 12, 2001 06:55 AM
