quick question
Old Aug 22, 2010 | 05:29 PM
s2000maniac's Avatar
Default quick question
I havent been driving my s2000 for about 3 weeks or so. The trans is making clicking sound when I shift, so I stopped driving it. since then I been trying to save some money so I can take to a trans shop and let them look at it. Anyways my question is.... the car is in the garage with the top down. should I close the top or just leave it like that? thanks
Old Aug 22, 2010 | 05:39 PM
In The Year S2000's Avatar
I don't really know if it makes a difference one way or the other...personally, if it were going to sit for a while...I would just close the top to keep bugs or little critters from setting up shop in there. Probably not likely to happen, but better safe that sorry.
Old Aug 22, 2010 | 05:55 PM
Mark355's Avatar
I'd close it too.
Does your trans click all the time? Mine clicks loudly as I shift when it's cold.
Old Aug 22, 2010 | 05:57 PM
TPhong's Avatar
Is the noise coming from the transmission or from the rear end. It could possibly be the differential. How many miles are on the car? It could need a diff fluid change or it could be an axle nut (I think there is a TSB).
Old Aug 22, 2010 | 06:37 PM
BlackBearTX's Avatar
Do you like dusts and spiders in your car? Up to you. I don't get why this is a question, you can put up the top without even turning on the engine.
Old Aug 22, 2010 | 11:57 PM
well i guess i'll just leave it open...the car is a 03 w/ 130000 and as far trans goes.. i replaced the fluid with honda MTF and I replaced the diff fuid with le1605. my mechanic raised up the car while i was sitting in it and he told me to drive it. so I was going through 1st, 2nd, 3rd while he listnened. he told me told me either my trans fluid is low or my trans is completely gone and i should replace it. although the car shifts fine, except for the "click" noise. also the car was turboed b4 by the previous owner so maybe the trans couldnt handle all that power.
Old Aug 23, 2010 | 04:12 AM
Mike21's Avatar
it clicks all the time or only when you shift?
Old Aug 23, 2010 | 04:19 AM
nofearofdanger's Avatar
The S2000's diff isn't notorious for being strong. Especially with that many miles on it, maybe its time for a replacement.
Old Aug 23, 2010 | 07:10 AM
only when i shift, especially in 1st and 2nd gear.... also I have that "whining" sound through all the gears......
Old Aug 23, 2010 | 01:05 PM
emac0408's Avatar
Especially if the car was turbo'ed before too... you hear more about blown diffs than transmission problems with FI. I would look into the diff.
