quick turn in
Old Nov 6, 2006 | 01:24 AM
dyhppy's Avatar
Default quick turn in
what makes the S turn in so responsive? is it the placement of the wheels, balance of the engine/car and why dont most other cars feel similar?
Old Nov 6, 2006 | 02:13 AM
RACER's Avatar
Frame geometry, ride height, balance, alignment, suspension, tire choice, and the S's awesome steering gear box.
My S has the best steering of every car I have ever driven.
Old Nov 6, 2006 | 10:43 AM
^AnDre^'s Avatar
have you drivein an E60? the last gen M5 is simply phenominal....I wish my stook handled like that.
Old Nov 6, 2006 | 11:01 AM
RED MX5's Avatar
[QUOTE=dyhppy,Nov 6 2006, 05:24 AM]what makes the S turn in so responsive?
Old Nov 6, 2006 | 12:29 PM
dyhppy's Avatar
what can i do to increase the turn in on my ap2?
Old Nov 6, 2006 | 12:39 PM
Saki GT's Avatar
# Stiffen suspension.
# Bigger anti-roll bars.
# Extra-fat rear anti-roll bar.
# Alignment.
# Low profile tires with relatively stiff sidewalls.
Plus:
# SmalLer front tread on your tires
Old Nov 6, 2006 | 12:49 PM
dyhppy's Avatar
who makes the best rear roll bars?
ive got 225 tires on the front. would 215 give better or worse turn in?
Old Nov 6, 2006 | 02:38 PM
RED MX5's Avatar
Why would you want to do that?
There will be compromises in other areas.
If you want a faster initial turn-in, stiffer shocks or tires with a stiffer sidewall would be two options. You can also alter the turn-in with alignment (less toe in, more toe out). Just keep in mind that changing the handling in one area (like turn-in) will have effects on the handling under other conditions (like corner exit or straight line stability).
I love the quick turn-in of my MY00 AP1, but it has been shown to cause more than a few drivers some grief. I believe the AP2's are easier to handle under almost any set of circumstances so why change a good thing?
Old Nov 6, 2006 | 02:45 PM
RED MX5's Avatar
A narrower front tire (on the same width rim, and all else being equal) will give a quicker initial turn-in, because the sidewall will be stiffer (becasuse the bead is more spread out relative to the tread). However, the narrower tires will give less total grip up front, so as the cornering forces build after turn-in, the car will tend to understeer more, and this will slow the later parts of the turn-in. IOW, up to a point, the narrow tire will turn in quicker (all else being equal), but it will have lower limits, allowing the front of the car to slide sooner than it does with wider front tires. Narrower front tires will slow turn-in once they start generating larger slip angles than the rear tires.
Old Nov 6, 2006 | 02:56 PM
dyhppy's Avatar
i miss the ap1 turn in. the ap2 feels just slightly numb in comparison. wish i could just swap the steering ratio.
