radiator cap question
Old Jul 11, 2006 | 03:31 AM
AlX Boi's Avatar
Default radiator cap question
Sorry if this is supposed to be a common knowledge. I got a 1.35 Mugen radiator cap, but stock is 1.1. Everything about the car is stock, so there's no problem using this radiator cap right? I wouldn't need a better radiator? Please give me some info about this radiator/cooling system/radiator cap thing? Thanks.
Old Jul 11, 2006 | 04:41 AM
Ks320's Avatar
[QUOTE=AlX Boi,Jul 11 2006, 07:31 AM] Sorry if this is supposed to be a common knowledge.
Old Jul 11, 2006 | 07:17 AM
xviper's Avatar
A higher pressure rad cap merely holds more pressure and allows the coolant to get much hotter (more pressure) without boiling. It will not make the coolant run any "less hot" than before. If anything, it will let it get hotter if you drive the car hard in very hot climates.
Since this engine has a very efficient cooling system and the coolant temp rarely gets above 100*C, except when travelling in extremely hot weather (over 35*C), a high pressure cap is just ornamental. Of course, if you track the car, it will prevent boil over, but then, in such cases, maybe you should be thinking about things that will keep the coolant temp from getting that high - like a lower stat or a more efficient radiator. Otherwise, you don't need an aftermarket rad cap and if you do use one, you don't need a new rad either.
Old Jul 11, 2006 | 07:19 AM
xviper's Avatar
Originally Posted by Ks320,Jul 11 2006, 06:41 AM
My friend just kept saying that his coolant temp needle sits a tad lower on his gauge in the MR2 (turbo) with the cap on.
I think your friend is imagining things and perhaps is trying to justify having done this mod. It would defy physics to have happen what he observed.
Old Jul 11, 2006 | 07:58 AM
Ks320's Avatar
hehe true
Old Jul 11, 2006 | 09:04 AM
s2kshift9k's Avatar
hey you learn somethin new everyday
unclefester
Apr 1, 2017 06:10 PM
Soviet
Feb 24, 2015 08:16 PM
NFRTurboTerror
Jun 30, 2007 10:45 PM
RELIGION
May 17, 2007 01:22 PM
