Rear end steps out a bit.
Old Feb 12, 2005 | 10:13 AM
rai's Avatar
rai
Default Rear end steps out a bit.
I've owned now for 2.5 years. No spins :knock on wood:
I've fish-tailed once or twice in the rain. Basically going straing ahead but it got loose. But I figured hey it's raining what do you expect?
Also once or twice with cold tires (not fridgid out) maybe 38-40-C when going straight ahead on the 1-2 shift it stepped out a few inches. Nothing crazy, but if I was closer to a curb it could have been a problem.
Does this happen to anyone else? Why does it happen if straight ahead with equal traction L-R ?
Just curious.
Old Feb 12, 2005 | 10:19 AM
klee1113's Avatar
tire pressure?
Old Feb 12, 2005 | 10:20 AM
BoostLE's Avatar
There's always some crown to the roads so its not totally flat.
Old Feb 12, 2005 | 10:56 AM
Ckcrigger's Avatar
Happens to me, too.
Anything but dry and warm, I have to be careful with WOT at VTEC transition and with aggressive shifts.
Old Feb 12, 2005 | 10:59 AM
TwistedS2k's Avatar
do you have stock tires?
Old Feb 12, 2005 | 11:05 AM
Nick32's Avatar
happens to me all the time..
SpeedxRacer's Avatar
Happens to me when its cold out... pretty fun but also dangerous when your fishtailing going 40.
Old Feb 12, 2005 | 11:13 AM
reedkr2's Avatar
It happened to me too. I had about 7k on the car, tire pressure was good, spring spacers were removed. All I can thing were the road surface having maybe too much loose gravel or the tires were not fully warmed up.
Old Feb 12, 2005 | 11:31 AM
rai's Avatar
rai
Yea stock. Around 6K miles on them.
Def not warmed up. But like I said it was dry and straight ahead, but it did step out away from the center of the road that is down the grade. Might have been rock-and crap from the salt/gravel they put on the roads around here.
Old Feb 12, 2005 | 12:09 PM
pness's Avatar
rear and end stepped out on me on a compleatly stright road.35 degrees and a 8500 rpm shift 1st to second. was a little freaky.
