Rear/Front Gaps?
Old Jul 25, 2011 | 02:03 PM
Kaneda215's Avatar
Default Rear/Front Gaps?
I'm not sure if this the case with all s2000's but when I measure from the center of the wheel to the metal of the fender, I get the same measurement all around. Although, I feel like there is still a larger 'finger gap' in the fronts than the rear. Does anyone know why this is?
Edit: Should I be aiming for equal gap between fender and wheel, or equal length from center of wheel to fender?
Old Jul 25, 2011 | 05:31 PM
downloader's Avatar
I don't know exactly what you want to measure, but the proper way to measure ride height is the jacking points to the ground on level surface
Old Jul 25, 2011 | 08:23 PM
Kaneda215's Avatar
I'm concerned with the space between tire and fender. Even though the wheel gap (measured from middle wheel to fender) is the same all around... the visual space gap is different. I don't know any other way to explain this.
Old Jul 25, 2011 | 08:26 PM
ahrmike's Avatar
The wheel arches are different. The front should have a wider arch which I believe is to help clear the tires when they're turned
Old Jul 26, 2011 | 06:55 AM
Kaneda215's Avatar
So does that mean it gives it more gap?
Old Jul 26, 2011 | 11:19 AM
Not Sure's Avatar
Your front tires have a smaller radius than your rear tires. Duh.
Old Jul 26, 2011 | 12:03 PM
352s2000's Avatar
Old Jul 26, 2011 | 12:30 PM
Kaneda215's Avatar
Hahha, noooo. Really? I had no idea that the tires had different depth, and thought that they were the same sitting on 17" all around.
Ok, well what am I aiming for then (for those of you that have corner balanced)?
1. Equal length from center of wheel to fender
2. Equal gap between tire and fender (finger gap)
tweaks2k
Apr 9, 2012 11:32 PM
Kaneda215
Jul 26, 2011 04:40 PM
dorami
Dec 15, 2008 07:28 AM
316s2k
May 20, 2007 10:15 PM
