Rear versus front tire wear
Old Sep 9, 2003 | 03:48 PM
robb's Avatar
I just checked the tread depth on the front versus rears on my S and I couldn't believe the diffrence. Fronts have substantially more tread then the rears. I have 3800 miles and I do drive agressively but I have never spun the rear tires. I was wondering what kind of mileage others have gotten out of their tires? I did a search for this but not much came up on this topic.
Old Sep 9, 2003 | 03:53 PM
Ace10's Avatar
there are exactly seven million one hundred fifty two thouand three hundred twelve threads on this topic.
Old Sep 9, 2003 | 04:33 PM
3ngin33r1's Avatar
Try this:
http://search.s2ki.com/search.php?q=tire+wear
You will wear the rears more then the fronts on the S2000, this is normal.
Old Sep 9, 2003 | 04:57 PM
robb's Avatar
Thanks 3ngin33r1
Old Sep 9, 2003 | 05:14 PM
Fongu's Avatar
robb,
I'll throw in my 0.02 cents. My rears are a hair from the wear bars with 14k kms (approx. 9000 miles). My fronts are actually not too different from the rears, 3-4 hairs from the wear bars, but I do autocross and do the occasional track day.
To sum up most of threads I've read, the rears last from 8000-15000 miles and that regular use will allow two sets of rears for every set of fronts. To maximize treadwear you can "rotate" tires left-right by remounting them. You can also use a less performace more tire wear friendly alignment by reducing the camber and the toe in on the rears.
Old Sep 9, 2003 | 05:18 PM
3ngin33r1's Avatar
Emphasis on remounting, don't just pull off the wheel and swap them.
Unless I'm mistaken because I'm tired but the S02s are directional.
Old Sep 9, 2003 | 05:21 PM
robb's Avatar
Thanks Fongu. My biggest concern with the treadwear is not necesseraily having to shell out the $$ for new tires but losing traction while I'm driving. I'm going to make sure I monitor the tires frequently.
Old Sep 9, 2003 | 05:27 PM
PWRMKR's Avatar
Trip on this.
I replaced rears at 30,000 miles. I still have the original OEM fronts at 49,000 miles. I need to replace them before I hit 50k.
Old Sep 9, 2003 | 05:28 PM
robb's Avatar
You are right I did see some posts in other threads stating the S02's are directional.
Old Sep 9, 2003 | 05:51 PM
mina's Avatar
I haven't checked the treads on mine yet, and I have over 5,000 miles. I guess I better do that tonight, as well as (re)check oil level and tire pressure.
