rear wheels tilted inward - problem?
Has anyone noticed that from the rear view of their car that the rear wheels appear to tilt inward at the top near the fenders?
I just received my 2002 blk/blk and it appears that the wheels are slanted inward (ironically, the right (passenger side) more than the left). It is not that pronounced, but it does cause me some concern.
Also, I had a 2001 blk/blk with the same issue. Is this normal for the car/suspension?
Thnx
Thnx
If i'm not mistaken, it has a dual affect, i might be wrong. When the suspension rolls, it puts more tread on the ground, and applies the force so along a somewhat different plain so it grips better. Think of the plain that a motorcycle applies its tread along, when they are tilted 45 degree's to the side!?!?
Brandon
Brandon
Originally posted by baknblak
...(ironically, the right (passenger side) more than the left).Thnx
Didn't even read the part about being canted on one side more than the other. Unless you took a look at your car while in a mad crazy turn, then yea, something's most likely not right. Like we all siad before, its normal to have a negative camber, but the camber is equal on both sides...
Brandon
Brandon
Have the dealer put it on the alignment rack and check the specs. Have the factory alignment specs on hand just in case the dealer does not. If it's true that one side is more negatively cambered, have them adjust it.
