Redline Water Wetter
Old Aug 24, 2005 | 01:54 PM
WVtwisties's Avatar
Default Redline Water Wetter
So I've decided to start this topic after searching and finding nothing..looked at FAQ's and didn't see anything either. I'm sure someone (xviper) will throw a link at me but I'm curious about if anyone is using this product???
I'll be doing a couple autox's and track days within the next 2 months so I was thinking if my car is ever going to heat up it will be soon. My mods (see sig) don't involve the engine so I'm guessing that will have nothing to do with my situation.
Advice???
Old Aug 24, 2005 | 02:05 PM
Dolemike's Avatar
Remember seeing a thread on this a while back, not to mention I think I asked the same question last year around this time. While I think you will see improvements, I have heard to be careful with which antifreeze you use, because with the addition of RWW it could turn the fill can black or something like that. Some people in here have also said that a few years back RWW was forced to change the composition and it isnt as effective as it was then and that adding soap in the coolant is almost as good. Ill let other fill you in on that one tho.
Old Aug 24, 2005 | 02:26 PM
Partshelper's Avatar
I heard only good about it, About to put some in my car tomorrow so I will let you know.
Old Aug 24, 2005 | 06:30 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Ad a few drops of dishwashing liqid,in it(Dawn,palmolive etc...)does the same thing,at $0 cost!!!
Old Aug 24, 2005 | 07:24 PM
SIIK2NR's Avatar
Another WW user here....
Old Aug 24, 2005 | 07:29 PM
Wisconsin S2k's Avatar
moving to S2000talk. general product questions go there.
Old Aug 24, 2005 | 07:53 PM
speed4tu's Avatar
I put some in my car, I couldn't tell any difference, but it is in there. It's another one of those placebo things. I put it in there so there must be a difference.
Old Aug 25, 2005 | 06:09 AM
WVtwisties's Avatar
cool..thanks people..i'll be putting it in today!
Old Aug 25, 2005 | 06:42 AM
Sebringer's Avatar
I run Water Wetter and distilled water only during summer months. Has helped keep things a liitle cooler. More cooling mods on the way, Hondata, etc.
All water wetter does is reduce the amount of foaming (bubbles) in the cooling system allowing more water (and less air) to contact the hot surfaces and transfer the heat. Dont see how a soap detergent would reduce bubbles?!...
Old Aug 25, 2005 | 06:49 AM
Try it,you'll like it .
It's all a matter of superficial tension!!!
