Reducing rolling resistance?
Originally Posted by sahtt,May 19 2010, 11:43 AM
You can't simply "turn on" the tire surface's ability to stick to the road only when you need it.
It's based on the same principle as trying to roll a tire with sticky material on it versus a tire that doesn't, although much less obvious in nature of course.
Your experience is meaningless,
but that's good you haven't noticed decreased mileage; wish I could say the same.
BTW, early hybrid cars had special low-rolling resistance tires with tread compounds significantly SOFTER than normal high-mileage passenger car tires. UTQGs in the 100s and 200s. It was a major gripe for some, the tires didn't last nearly as long as most "normal" car drivers are used to.
Interesting link related to this discussion (including molecular bonding!):
http://www.school-for-champions.com/scienc...ion_rolling.htm
Excerpted summary:
Another link: http://www.tyres-online.co.uk/technology/silica.asp
Excerpted summary:
Rolling friction is the force that slows down the motion of a rolling wheel. This frictional force is typically a combination of several friction forces at the point of contact with the ground.
When the materials are both hard, static friction and molecular friction slow down the rolling. When the wheel or tire is soft, its distortion slows down the motion. When the other surface is soft, the plowing effect is a major force in slowing the motion.
